Bester Antenna
214 posts in this topic
23 минуты назад, Администратор сказал:
,,,да...!!!
2 антенны вместе? Или 1?
,,,try as you like...I think two is better...!!!
06.08.2024 в 15:48, Администратор сказал:
,,,испытайте как хотите...Я думаю, два лучше...!!!
What is the best way to position 2 antennas? Vertical, horizontal?
,,,one antenna with horizontal polarization and the other with vertical polarization...!!!
On 05.08.2024 at 16:12, Admin said:
ДэвидЭР,
,,,эта антенна Bester только для 50 Ом, для 75 Ом нужны другие размеры для питания...!!!
Is it possible to simulate a 75 ohm antenna?
,,, yes it is possible, I told you before...!!!
13 minutes ago, Admin said:
,,, да это возможно, я же говорил тебе раньше...!!!
Fine. Will the drawing be ready?
Where is the horizontal and vertical polarization to place 2 antennas?
1 minute ago, DavidER said:
Have you modeled a 75 ohm antenna?
,,, may I try today ... !!!
DavidER,finally, I managed to complete this antenna,.with 75 0hm impedance(1,95---2,2 GHz)...
,,, another version of Bester Antenna by Alexander Bars....
and positioning this antenna in the focus of an offset parabolic dish
