Dlink ANT24 1800
,, yes, I know it... long ago...!!!
,,, this antenna is very complicated to execute on the PCB and for so many patches, the gain is very small..!!!!
The patches should have a simpler geometry...!!!
,,, this variant in the air, is more interesting but with simpler patches...!!!
I know , you hate DIELECTRICS!:D
 JOMY ,Thought , yo could give it a GO at the simulation , i get 18.8 dbi , low , very low EFFICIENCY
,,,Clanon, air antenna, other dimensions are required...!!!
YUP...EVERYTHING changes...changing substrates....have you worked with STYROFOAM ? (polystirene foam) if so...what constant and tangent loss should i use...some say 1.11 dielectric and some 0.003 loss...LOW DENSITY foam...
I use the dielectric constant = 1.2
Efficiency is low...i blame the FR4 ... so far...(not sure though)
,,, clanon, you, can post its technical drawing...???
I am most interested in the transmission lines .. !!!
i dont' undestand this part ...;
9mm desde reflector to cara de cobre PCB
6 mm entre reflector y placa cobre no cara de cobre.
must be 6mm to square...?
,,, okay, if you put in place of rectangular patches, elliptical patches, like, what do you say ... ???
notice 8 internal patchs at HIGHER frecuency than 8 external patchs...two paks of resonance...it seems..
PS: the SCREWS are very IMPORTANT! there
