Anteks sector Petra BB PS70
Broadband sector panel antenna with vertical polarization. KU=12.5-14dBi. Width days is 70 degrees. (level -3dB). F=1700-2700 MHz.
Electrical characteristics
Operating frequency range, MHz 1700-2700
The gain in the GSM1800 band, dBi 12.5-13
The gain in the 3G range (1.9 to 2.2 GHz), dBi13-13.5
The gain in range of WIFI (2.4 GHz), dBi 13.6
The gain in the range of 4G (LTE), dBi 13.6-14
Width of DN in the horizontal plane, deg 63-77
Days width, in vertical plane, deg 14-23
The sidelobe level is not more -10dB
Input impedance, Ohm 50
The CWS in the range of GSM1800, nothing more 1.5
The CWS in the range of 3G/4G/WIFI, not more 1.4
Permissible power watts 50
Polarization vertical
Weight with mount, g 1130
Mount on the vertical pipe with a diameter of 25÷52mm
Overall dimensions without mounting, mm 411 x 152 x 45
Allowable wind speed, m/sec 25
Connector N-female
Material of protective box ABS
Antenna material galvanized steel
Protective coating powder polymer paintsand
Operating temperature range, °C-40.......+70
