akoneko47
Omni 15dbi outdoor
32 posts in this topic
I'm beginner for antenna
I have ordered Omni 15dbi outdoor and they sent the product is in an incomplete condition. (The center axis of that pole slipped inside )
I try fix tem but i saw "The two poles are linked together"
And I want to know this is the right thing And it works normally ?
The two poles (line +, line -) are linked together
it works normally ?
Edited by akoneko47
,,,you can give the dimensions of this omni antenna...???
,,,for which the frequency works..???
No, I would like all the dimensions for the whole antenna..!!
@Admin
Sure, Pls make sure it's okay and  works normally because I have 3 days for return to seller
Thank
I think the antenna is correctly built but only the connection socket is not OK. Better to return the product...!!!
", that's how it should look ...
Oh! sorry for unit of measure
and If it just has a problem at the socket, I can fix it by myself.
Thank a alot @Admin
After this I will seriously study the antenna.
10 hours ago, Khubaib said:
Hi, can i have complete design of this antenna?
That might be close to reality....
yes sir, i also need the dwg or design files, iam awaiting for your reply sir.
3 hours ago, Admin said:
,,,why dwg file...???
so that i can get idea for my reqiured 340MHz antenna, tuning to 340MHz and i'll clear the doubt in port assigning.
On 12/21/2019 at 1:18 PM, Admin said:
sir what is that white coloured material between the copper tubes? and if that copper tube is hollow how it stand fit by means of that white material?
,,,there are insulating spacers compared to the outer protection tube....!!!
sir iam designing a omni antenna in HFSS, should i include this spacer material or can i give gap(empty space)?, thanks in advance sir.
,,,to make the simulation easier, you can leave air space...!!!
How is it made?
i know coaxial COCO only :
(reasembling 1800MHz antenna to 1296MHz
WhatsApp Image 2024-07-02 at 12.03.34(2).jpegWhatsApp Image 2024-07-02 at 12.03.34(4).jpeg
