Sector Antenna 2,442GHz
89 posts in this topic
Practice Valet ....
A sector type antenna with bester-patches
,,,simply the best...rectangular patches suspended on polystyrene foam
in this variant, the inclined wing reflector and isolating spacers
On 8/26/2017 at 8:39 PM, Admin said:
Antena tipe sektor dengan patch terbaik
can my brother tell me the detail construction, the shape is long, the width of the reflector is about 100mm, the gain is about 16-20dbi, the frequency is 2422Mhz.
16,,,,19dBi it can only be obtained with at least 8 patches....!!!!!
And there's also an 8-patches antenna sector with circular polarization...
My old variants of the antenna sector...
,,,a simplified constructive solution with Cu-wire transmission lines...
,,,something like that(with Cu Wire), it's easier to build....!!!!
A new patch format...for broadband
if odd, how is that radiation result? would not it be mismatched
as always, I have seen, the number of elements if not one, two, four, eight. only this time I see there are three, maybe there are also five or seven.
"""depends on the position  of the feed point  and transmission lines ......!!!!
a sector antenna variant with curved dipoles...
,,in ABS tube(110mm diameter)...
,,,and here is a model sector antenna, made by the user Pragata...
please send me file .cdr ekstensi
I do not think I have them anymore....!!!
it's a long time ago...!!!
can send other models
Can this patch to be a Mimo patch?
