Sector Antenna 2,442GHz
89 posts in this topic
test..... modified with CST Studio
,,,the antenna is powered by the SMA port...???
On 23/04/2017 at 8:35 PM, Admin said:
After an idea of Vman...
Sector Antenna 2442mhz.cst
I take it from here ... then change some parameters, just change the size and material and shape of the reflector
,,,it has the wings not inclined...???
yes, it has 90 degrees of wings, resize a reflector,, 460mm long and 117mm wide, with 16mm wings
1 hour ago, Eric said:
any updates about the details?? thank you
,,,not yet...!!!
,,, but soon .. !!!
,,, this is the promise made previously....
On 8/25/2019 at 6:07 PM, Eric said:
spasibo bol'shoye, admin
,,, you mean you say .... thank you very much, admin...??!!
,,, without Russian language, please ... !!!
Admin, i still not understand about + & - connector. Can you draw in sketch format?
11 hours ago, Admin said:
I mean this design for ground and plus connection and also ballun and reflector
I still not understand to build it. I want to build this one.
,,,but this antenna it"s available for use between 4.9 to 6.4 GHz and does not make the subject of this post...!!!!
Yes. I want to modified this design to 2.4 combined between heix and sector. My mission is to improve gain 2.4 wifi hotspot.
I still thinking how 2.4 gain very short. Not like cell signal can reach few km to user.
If with 100mW - 1 watt  power and massif mimo design on 30dbi can 2.4 reach to user on 1 km?
Raul, if you have such an antenna, you can post a few details and dimensions ... ???
