MIMO antenna 4G LTE 1800 Mhz
68 posts in this topic
Triton_Mgn says,,,
Good afternoon, give the antenna a good antenna for the 1800 MHz mimo
Found 2 antennas on the forum:
1 - http://www.lan23.ru/forum/showthread.php?t=12671
But, unfortunately, not its size at the desired frequency, tell me who knows.
2 - http://www.lan23.ru/forum/showthread.php?t=10879
Could you tell me the thickness of the disc, can I use galvanized?
In the drawing, the antenna of this size for the lower frequency 1747,5 pink color,
and upper 1842,5 green. Why, then, in the drawing there are dimensions in blue?
My answer is,,
it can build a patches antenna instead of a disks, a horizontal patch antenna group (at one end of the frequency band) and the other group with vertical polarization (at the other end of the frequency band)
this antenna also I need to try to make
But a little less frequency
Edited by chilanzar2
how much?
на рисунке , эта антенна на 1747 и 1842
а мне нужна антенна на 1780 и 1870:(
"Ok but these dimensions are very good for my antenna, 1780-1870 MHz VSWR <1.2
ok Erkin, but I saw you know how to work in autocad, it's simple, it's just rectangles patches ... !!!
но, есть два размера, например  а 77 78,   а1  67 68.  Я этого не могу понять
какой размер правильный 67 или 68 ?
,, but, there are two sizes, for example, a 77 78, a1 67 68. I cannot understand this
what size is the correct 67 or 68?
"There are two pieces of each
one for the 1720MHz frequency and the other for the 1840MHz frequency
it does not see too good ... !!!
what do you mean with 1 patch...??
this is another problem ... !!!
the main thing is to keep up the real dimentions,,,!!!
8 hours ago, chilanzar2 said:
the antenna will work?
did you make two antennas of different sizes?
Erkin, это два типа антенн для двух частот с их соответствующими размерами,,,
Erkin, these are two types of antennas for two frequencies with their respective sizes ,,,
I realized this yesterday. Today, I will re-cut. Jomy, as I do with short feed connector?
