chilanzar2
Diary of a solid man-a beginner antennae in excess of high frequencies.
235 posts in this topic
Got it. It seems that the truth is the TDD system. But, why do they have antennas MIMO?
I think the MIMO antenna rotated 45 degrees, turns into the SIMO antenna
MIMO-MIMO
MIMO-MISO
MIMO-SIMO
MIMO-SISO
MIMO-Miso-muco-milo-mido....:(
Then they are right when they say MIMO. MIMO antenna is needed to take antiphase reflected signals.
Jomy, our antenna can just be tuned to the center frequency of 2382. There will be 2367 and 2397 at the edges. I think correctly?
Edited by chilanzar2
Yes, it's right ... !!!
Erkin, some news with the antenna ??
4 pieces manufactured, with low swr. I gave 2 pieces to this company, 2 pieces to myself - for experiments.
This result can be achieved if you move the top-bottom strip lines. In the photo there is an extreme port. But, the central port is difficult to configure, the SWR is worse a bit
Yes it is, we have to work at this central port,,,!!!
All this I bought less than $ 3. I just do not know where I'll use them.
Nylon cogs also came from China - in vain I spent money on them. Tomorrow I'll take these nylons in the mail
3 dollars is not much, keep them, very good for the future, if you still say you're passionate about wifi-antennas...!!!
Oooh .. I'm still as passionate! I'm sick on the antennas. I do not sleep, I do not eat, I do not rest, I do not watch TV .... it's a disease, a mental illness. And yet, the desire to make money.
But that, do not you like ... ??
Like! I do not speak English well, and the interpreter does even worse
I thought not to complicate the execution of this antenna and to keep only laser cutting but if we add bending operations to the  WIMAX antenna then it(antenna) becomes more efficient,,,!!!
"Look at this, as it looks
Экспериментировала с кольцевыми участками. Дальняя порт - можно было нагреть до swr1.01 (2389F). Этот порт очень прост в настройке. Но центральная одна очень трудно дать. Очень сложно.
Experimented with ring sections. Far port - it was possible to heat up to swr1.01 (2389F). This port is very easy to configure. But the central one is very difficult to give. Very difficult.
,,, я буду пытаться решить проблему центрального порта,,,,!!!!
,,, но этот вариант антенны, почему бы не попробовать с Anritsu?
,,, I will try to solve the problem of the central port ,,,, !!!!
,,, but this version of the antenna, why not try with Anritsu?
Теперь попробовать это тоже,,,
I work with all the patch variants, I check. It is very difficult to keep the central port in the right parameters, on all patches.
At what frequencies does this patch work? Wide range?
And, can all the holes in the directors be summed up so that all the patches are normally located on the reflector. And then, for each new patch director, he prepares a separate reflector ... expensive
