AX-1800 MIMO 2x2 OFFSET offset irradiator 4G (LTE1800)
Efficient feed for offset reflector antennas for 4G networks (LTE1800) support MIMO technology. F=1.7-1.9 GHz, the Resulting KU with reflector up to 27dBi. Connector type - N-female (50 Ohm).
Own gain, dBi=9-10
The width of the days in the H-plane by level -10dB, hail=110÷120
Width days in E-ploskosti level -10dB, hail=90÷96
Isolation between inputs of the antenna, not less, dB=28
Input impedance, Ohm=50
SWR in the frequency range, not more=1,5
Polarization...vertical+horizontal
and more . dimensions for fabrication in metal
,,,I will soon post my dimensions as well...!!!
a remarkable convert it to 75 ohms
...this antenna it"s with  75 ohms ports...!!!
Ok, to keep in mind ... !!!
But what modem does the 76 ohm impedance at the imput,,,???
Port2 goes, port1 needs to be resolved
I kazhitsya that with the second port problem
How does Port1 look .. ??
Irg, do you know?
Remains to be solved Port1 in the future...!!!
photographed 75 Ohm and not 50 Ohm
it's inside the box
Irg,,,,I would be interested in this sight  of view,for the second port....!!!!
On 28/10/2017 at 10:02 PM, roman55524 said:
will there be new correct sizes?
I M SO CURIOUS and interested TOO  !!!
