Efficient feed for offset reflector antennas for 4G networks (LTE1800) support MIMO technology. F=1.7-1.9 GHz, the Resulting KU with reflector up to 27dBi. Connector type - N-female (50 Ohm).
Own gain, dBi=9-10
The width of the days in the H-plane by level -10dB, hail=110÷120
Width days in E-ploskosti level -10dB, hail=90÷96
Isolation between inputs of the antenna, not less, dB=28
Input impedance, Ohm=50
SWR in the frequency range, not more=1,5
Polarization...vertical+horizontal
