3G Panel Antenna
By Admin in Antennas for mobile communications,
Work offline and far. The distance to the BS for about 15 km, the signal is UMTS and HSPA, according to the Internet 2100 MHz. Materials include galvanized only 0.5 and 0.7 mm and a bit of copper sheet 0.7 mm bolts and nuts too. At the moment, made and works one antenna triple bi-Quad sometimes at a rate of 200 kbit/sec. in the evening no more than 30 max. 3 HSPA peak. But 3mm wire is no more and all hope for iron and broadband patch.
In the attached file (Patch Broadband 3G 1935-2140 MHz) represent a “project”.
  • 9 replies
