AGATA 2x2 MIMO - wideband panel antenna 4G/3G/2G (15-17 dBi)
35 posts in this topic
On 18.05.2017 at 0:48 PM, chilanzar2 said:
O.o...They do not register me. When they found out that I was from Uzbekistan, they switched off the phone. They say that foreigners have a lot of fuss
Yes this is true. Unfortunately, bureaucracy and corruption do not allow us to fully work on the external market.
Ohhh..!!! Igor Panchenko! I am very surprised. He's one of the great engineers of microwave antennas our time. Engineer of the Russian factory of microwave antennas "Bester".  I like it.
Что это за антенна? You can show the back of the antenna.
как называется эта антенна
what is this antenna called
AGATA-2F 4X4 MIMO
Constructive details of the antenna...
,,, and a few more pictures with details about the impedance adjustment lines of antenna...
AGATA-2F 2X2 MIMO
Operating frequency range, MHz 1700-2700
Gain, dBi 15.0-18.0
Bottom width (-3dB), deg 16-50
Side lobe level not more than, dB -12
Port decoupling at least, dB 25
Forward / backward ratio, dB 26
Input impedance, Ohms 75
SWR in the operating frequency range at the inputs, max. 1.6
Permissible power, W 10
Polarization of received / emitted waves vertical, horizontal
Mechanical characteristics of the antenna
Weight with mounting, g 2115
Overall dimensions without mounting, mm 240x450x50
Connectors 2 x F-female
Antenna Material, Galvanized steel
Material of the protective box, Polycarbonate
Dust and moisture ,protection class IP67
Protective coating ,Polymer coating
Operating temperature range, -50℃ to +80℃
,,,the antenna from the previous post is AGATA-2F 4X4 MIMO from Antex with the following characteristics...
Operating frequency range, MHz 1700÷2700
Gain, dBi 13.5÷17.0
Bottom width (-3dB), deg 16÷52
Side lobe level not more than, dB -11
Forward / backward ratio not less than, dB 18
Port decoupling at least, dB 30
SWR in the operating frequency range at the inputs, max. 1.7
Polarization of received / emitted waves Vertical, Horizontal
Weight, g 2830
Overall dimensions, mm 400x400x35
Connectors 4хF-female
Antenna Material Galvanized steel, Steel
Material of the protective box Polycarbonate
Dust and moisture protection class IP67
Protective coating Powdered polymer coating
Operating temperature range -50℃ to +80℃
