Antennas for Drones
191 posts in this topic
This is a 1.2GHz antenna version with pseudo-elliptical polarization
DELTA antenna, another kind of miniature antenna on PCB for 5.8GHz
Anyway it's sub-miniature, about 30x30mm
And here are the  CSTfile
thickness FR4 = 1mm
DELTA 5,8GHz.cst
A new form of biquad antenna
Antenna circular polarized (clover)
Today I'll show you how to make yourself famous "clover" from IBCrazy.
What is it: a need for stable and long-range FPV video link. If you omit the technical details, it turns out that for the same power in antenna, circular polarization easily interrupts the linear range and stability.
it purple the position of the transmitting antenna in space. In contrast to the linear (normal whip antenna). There is rotate one of the antennas 90 degrees and oppa. Polarization from vertical became horizontal. Ie necessary and the other antenna to rotate as well. If you do not turn, it is a minus signal.
For 2.4 GHz, the sizes to get the antenna oriented in 2440MHz with bandwidth more than sufficient to cover all channels of this group, from 2370 to 2510MHz should be the following:
The length of the Central wire = 3mm
Length of wire = 122,8mm
Long side (the length of the straight segment + length of the Central conductor) = 35,2mm
Short side (the length of the straight segment) = 32,2mm
The arc angle = 90 °
Tilt angle = 50 °
For the range 1.3GHz, with a center frequency of 1280MHz, the dimensions must be as follows:
Length of wire = 236,8mm
Long side (the length of the straight segment + length of the Central conductor) = 67,2mm
Short side (the length of the straight segment) = 64,2mm
Tilt angle = 50 °
Dimensions for the frequency 5740MHZ, one of the channels points Fat 'shark:
The length of the Central wire = 2mm
Length of wire = 50,9mm
Long side (the length of the straight wire + the length of the Central wire) = 14,8mm
Short side (the length of the straight wire) = 12,8mm
Tilt angle = 50 °
This appearance of the antennas at 1.3 GHz (left) and 2.4 GHz (right), in order to give you an idea of sizes:
Constructive Details
VAS 5.8 Ghz Air Screw Antenna (RHCP) by Video Aerial Systems
Model Petra antenna for 5,8GHz on FR4 #1mm
Overall dimensions 10x48x66mm
But on this picture there are two different antennas.
First one is some kind of QFH antenna and it's for 1.2ghz.
,,,I do not think so, this is QFH(Quadrifilar Helix Antenna)
Yup, i know QFH. But for me looks like some king evaluation of such antenna made from thin fr4.
Ok i've looked at that antenna. It's not qfh.
So what a kind of antenna is that ?
Look carefully at the image above,,,....!!!!
looked, and ?? :)
I've got that white antenna. And few minutes ago dissembled it :)
circle is 0.5mm fr4 and folded fr4 is 0.35mm
did not you have anything wrong?
i forget - thickness of fr3 sheet :)
diameter of circular fr4 is 45
height if folded fr4 is 21.7
I thought this miniature antenna in the sense of its execution by a simple turning operation in a few pieces (4)
The vibrator(1) is made of copper, the rest of the elements(3) are made of duralumin.
This patch-yagi antenna has a circular polarization...
These are the dimensions of the antenna...
,,, and here's a wonderful practical achievement of our assiduous collaborator, TommyD ...
", and related simulations ...
But I think this yagi-biquad should be tried as well...
I am thinking about making a simple dipole yagi to try some longer range 5.8ghz survey style flying
.., without reflector...
,,,with reflector...
Tilt angle = 50 °
it is suitable for 2.4ghz wifi router or just for drone?
Aomway Tripple Feed FPV Antenna
Good radiation efficiency. Most FR4-based patches have terrible efficiency because FR4 is very lossy at 5.8 GHz.
Good axial ratio, not just directly perpendicular to the patch but also off-center.
Specifications
Center frequency: 5.8 GHz
Bandwidth: 700 MHz (5.3– 6 GHz)
Matching: S11 < -20 dB,
VSWR < 1.5 (at center frequency)
Axial ratio: < 1.3
Antenna gain: 8 dBi
Half power beam width: 55° (horizontal and vertical)
Radiation efficiency: 83.5%
weight :15g
Connector: SMA (Blue) / RP-SMA (Red)
