Antennas for Drones
191 posts in this topic
4 minutes ago, Admin said:
,,,okay, I will try to do a simulation of this antenna...!!!
...the input impedance is 50 Ohm...???
Yes ,50 Ohm.
read about such antennas. Made a connection point as in the photo. It seems better but I still want better
Aksonx2, please excuse me, I have small problems with the simulation program and I'm going to be a little late with it...!!!
Don't worry. It's ok. I'm also waiting for windless weather to test this antenna option in field flights. Science requires sacrifice!!!
Aksonx2,
,,,I finally managed to do the simulation for you, but it seems that the antenna is not quite successful..!!!
1 hour ago, Admin said:
Aksonx2,
Thank you so much for your time. It also seemed to me that this antenna connection option is a little incorrect.
I changed the location of the cable connection in the middle of the connection line, above I posted a photo. The results were as follows on the analyzer. The results above are incorrect since they were in a small room and industrial interference was detected on the air
,,,my friend, for which frequency do you want the antenna to work...???
I apologize for the arrogance:) do not share the project file? In order not to waste your time, I will play with the size of the antennas myself.
okay, maybe later, I have a little work now...!!1
I fly this antenna now at 1320 MHz. I suggest you stay that way. Cut less:))))
changed the connection location and replaced the wire with strips in the connection.
If you have free time, can you check me out? I'm still in CST. According to your articles on the forum. A little later I will put optimization
1320patch.cst
,,,did you really buy this antenna from the store...???
IIRC the WIRES UNDER the discs (closer to reflector) gave less reactivity ...improving VSWR...
Crosshair®Xtreme Pair for HDZero Goggles
The HDZero system works by using 2 diversity systems, one on the left side and the other on the right and then combining the best signals of both of those into one HD signal.
Specifications:
Polarization: RHCP or LHCP
Gain: 10.25dbic
Axial ratio: 0.99 (as measured)
Bandwidth: 5300MHz-6400MHz
Beamwidth: 120 degrees
-3db beamwidth: +/-30 degrees
Mounting Solution: Black Included (other colors optional)
Connector: SMA Male 90
