Universal antenna NITSA-2
Universal antenna NITSA-2 is designed for use with included c cell phones, modems or repeaters standards GSM900/GSM1800/UMTS900/UMTS2100.
Electrical characteristics
Operating frequency range, MHz 890-960/1700-2200
Gain, dBi 9 / 9÷11
The width of the days in H-plane, degrees 70/50
Days width in E-plane, degrees 70/53
Input impedance, Ohm 50
SWR in the frequency range, not more 1,5
Permissible power watts 20
Polarization vertical
Weight with mount, g 835
Overall dimensions, m 0,2x0,2x0. 045
Connector N-female
The material of the radiator galvanized steel
Material of protective box Polycarbonate+ABS
Nitsa2 vswr..
,,, a simulation attempt...
,,,but without this line of adaptation....
,,, the antenna dimensions with adapting lines ....
