Universal antenna NITSA-2
By Admin in Antennas for mobile communications,
Universal antenna NITSA-2 is designed for use with included c cell phones, modems or repeaters standards GSM900/GSM1800/UMTS900/UMTS2100. Electrical characteristics Operating frequency range, MHz 890-960/1700-2200 Gain, dBi 9 / 9÷11 The width of the days in H-plane, degrees 70/50 Days width in E-plane, degrees 70/53 Input impedance, Ohm 50
  SWR in the frequency range, not more 1,5 Permissible power watts 20 Polarization vertical Mechanical characteristics Weight with mount, g 835 Overall dimensions, m 0,2x0,2x0. 045 Connector N-female
  The material of the radiator galvanized steel Material of protective box Polycarbonate+ABS   Nitsa2 vswr..
  • 2 replies
