Antenna KAPPA
47 posts in this topic
The antenna is intended for reception of TV channels 21-60
KAPPA.cst
hello Jomi. How are you and your health? Sorry to write in Russian, it's more convenient for me to express it! I have a big request for you! You can calculate the Yagi antenna for 690-770 MHz. If you do, then I will write what materials there are. Thank you in advance!
,,, hello Vova, I'll try to see how we solve it ... !!!
,,, but as you can see, this antenna works in your frequency range .... !!!
Yes Kappa is not a bad antenna, but it is broadband! But I would like to make a real antenna, designed according to the program for my range and from my own materials! You can make a mouthguard, but it's problematic !!!!
,,, yes, the antenna I simulated above, works very well on the frequency of 0.8 GHz...!!!
Hello Jomi! You probably forgot about me? Yes, it is clear that there is not enough time for everyone! I wanted to ask. Did you try to simulate Spindler's Yagi antenna, because you did Kappa! These are all antennas from the times of the USSR and were made according to GOST. By the way, the Kappa plant is still operating in my city. And according to Shpindler, I'm certainly interested in my range 690-770 Interestingly, before there were no devices or programs !!!!!!! ... Sorry in Russian.
You have some antenna sketches from Splinder's book....???
There is a PDF file at home.
By the way, Jomi, it is on the internet with a breakdown of sizes by channel! If you optimize then 10 email. option!
  Like this
from 690 to 770 you could use a NORMAL tube dipole NOT FOLDED but TUNING the TUBE's  diameter
How many elements...GAIN...? do you need
and WHICH KANAL ?
what tubes do you have?
colleague, Clanon, at one time I made a lot of dipole antennas, which are still with friends. Yes, simple and reliable !! On radio sites, there is a lot of controversy and discussion about Spindler's antenna. I still have this one counted at 2600, it works great !!! So I thought to do it for TV, but I would like to optimize !! There is an AL tube. 8 10 and 12mm. Boom - round 20mm 25mm and 18mm Square 15x15
It is necessary to overlap 2 channels 706 and 754 MHz
10 items will be ok. Reflector is the same Noise immunity is very important
This channels ? more or less...KANALs ...? if only TWO channels we need TWO dipoles if ALL channels only one dipole
better with one!
I thought so!
Clanon, they brought me an AL strip today. 15x2mm. This is in addition to the material I wrote to you yesterday!
19 hours ago, vova.gumerov said:
better with one!
I thought so!
so far i'm using
Boom 15x15 square (1mm)
tubing 8mm (1mm thick)
DIPOLE  15 x 2 mm
12dbi could be achieve with 7 + 3 elements BANDWIDTH is the hard thing to achieve (More than 50mhz)
Thank you very much, Clanon, for your work! Add as many elements as needed. Then I will use without an amplifier.
A dipole made in this way is very good from reactivity
oh it's a long antenna !!!!! I thought that you already calculated the antenna for me and that for 12dbi you need to add + 3 elements ???
Clanon, for one good small antenna, they will give 2 long ones !!!!
On 11/24/2021 at 7:43 PM, vova.gumerov said:
better with one!
I thought so!
Vova, this antenna is not broadband. It covers 2 adjacent channels. It is not suitable for your requirements. How long do you want the antenna to be?
http://radiotech.inf.ua/Shematic_PCB/HFtehniks/shpindler_anten.htm
is a great design you can USE the length you want , taking directors OUT from the TIP back (reducing GAIN)
the BALUN losses and bandwidth is of most importance
