Antenna KAPPA
47 posts in this topic
700mm the one i'm working on...i'll tell you if it works
all 8 mm tubes and double flat strip 15x2mm folded dipole and balun included (just put the cable tv in the antenna STRAIGHT)
On 11/26/2021 at 1:01 AM, clanon said:
Antex patent ;-)
Hello Jomi! I have yagi calculators. But this is a narrow strip. I did it on the middle frequency - not very good!
Or the same ATVKD-15/21-39 (TV antenna “wave channel”, decimeter range, 15-element, channels 21-39):
It looks like this antenna is pretty good...
Jomy try making it a LFA , doing an HORIZONTAL folded dipole , you can make it 50 ohms by that change and dimensions , the rest stays the same (director reflectors)
54 minutes ago, Admin said:
Похоже, эта антенна довольно хороша...
Джоми, здравствуй! Благодарю за оптимизацию! Графики действительно хороши!!!!!
Congratulations to all forum participants on Catholic Christmas
On 23.12.2021 at 4:22 PM, vova.gumerov said:
470-800 MHz
7 hours ago, vova.gumerov said:
470-800 MHz
520-850.
the size needs to be increased for 470-790.
On 25.12.2021 at 02:47, Harry36 said:
Clanon, can you extract the MMAN file? I need detailed dimensions for construction!
Vova,Happy New Year to You,with Health , Happiness and a Better New Year 2022...!!!
Jomy if you pass the cst i could try make it an 75 ohms LFA dipole...
from where...?
