Panel Antenna 15dBi
30 posts in this topic
hi Admin...
i do not have teflon, how about changed it with m6 plastic spacer??
,,,best. instead of Teflon spacers. uses metal spacers,,,
so... changed it with 10mm copper tube is no problem?? or with 10mm bolt??
it is not easy to find pvc tube with small diameter, how about rg8 coax, clean up the inside and using only outter jacket..
", it does not matter the diameter of the PVC cylinder, you give it a screw hole...
Well, I thought it was appropriate to make an improvement on my older antenna project, which is why I made this optimization...
how about housing/enclosure for this antenna, what is the best material??
i do not thinking to mounting this kind to the outdoor...
maybe another option like abs plastic, pvc or maybe arcylic
Edited by bejonet
"If you put the antenna on the electric pen, you can...!!!
Anyway, here I have presented another antenna panel construction...
,,,,good, it's good and so, but it needs a bigger diameter at the cookie cans....!!!
,,,, and the cover should be inverted....!!!!
diameter of reflector is 260mm, if it is work I plan to buy galvanizes or cooper sheet..
"It's good, but the cover needs to be reversed, kind of like ...
,,,good good very good....!!!
,,,congratulations my friend ... !!!
thank you... You are the best teacher....
I do not have 1mm cooper wire so i used 1.5mm too, it is influence or not..??
yes, the diameter of the copper wire , influences the impedance of the antenna...!!!
