Panel Antenna 15dBi
30 posts in this topic
On 11/24/2018 at 11:54 PM, Admin said:
yes, the diameter of the copper wire , influences the impedance of the antenna...!!!
yes, i was changed cu wire from 1,5mm to 1mm, it is working good... thank you!!
I will try to do it...!!!
UMTS-FDD frequency bands and channel bandwidths(3G)
1920 – 1980 MHz---Uplink
2110 – 2170 MHz---Downlink
Fm=2045 MHz
,,,that's it...!!!
,,,it seems that this antenna does not ensure the bandwidth frequency required...!!!!
,,,it is the narrow band...!!!
