4 by 4 FR4
Originally designed for 5.8 (with HIGH LOSSES and low gain)
Inverse engineered to 2,4 ghz wjith High GAIN and Better Efficiency s on FR4
...modelling right now...almost there...Close to 20dbi
,,, okay, success at work...!!!!
Forget to say SLOT FEED PATCHES
1mm Fr4
5 mm to reflector
Pinned quarter stub to gnd (reflector)...?
PS: NEEDs some fine tunning...yet... Gain could be smaller and VSWR wider under 2:1...
Clanon, you can give some dimensions to this antenna...???
1 hour ago, clanon said:
do you want the .CST...? (easier to do )
,,okay...!!!
I KNEW IT! ;) ...i was expecting you could fiddle with the distances ...there...(working on a 18dbi  24 dipoles right now)
,,, such a thing is not correct .. !!!
VSWR still a little high...2:1 in 802.11 band...
19 plus dbi , some horizontal sidelobes...
reactivity close to zero...
,,, to get rid of the lateral sidelobes, you need to reduce the distance x2...!!!
Sidelobes and narrow band...!!!
Well...they are UNDER -20db...so...not that bad...
Z for wideband a different story
I'll fiddle with x1 and x2...
JOMY...! HOW do i LOWER the VSWR...
antenna is GREAT but too INDUCTIVE REACTIVE...
too NARROW BAND...
distance to reflector change NO GOOD
distance to feed network NO GOOD
