Raul
Convert 2.4 quados 8 quad to 5.700ghz
H
Hello, can any one can convert this antenna to 5.700ghz and simulate it?
I want to test this antenna as Access point.
,,, for the construction of the antenna on the frequency of 5.7 GHz the coefficient k = 0.4284 is used to transform the dimensions...
1 minute ago, Raul said:
How about to put two antenna? Should i space it at 32mm?
,,,yes...!!!
Just now, Admin said:
,,,yes...!!!
It's from center antenna or side antenna?
it should be studied and simulated , since impedance 200 ohms (originally) will be 100 ohms for two ...but 4 of those would make a direct adaptation to 50 ohms (1:1 balun required)
and YES
,,, a simulation with the above dimensions (given by me)...
,,,the distance between the vibrator and the reflector as well as the other dimensions must be reviewed...!!!
The dimensions in yellow are for the 2300 MHz frequency...
hi
i want to build this antenna for 3570 mhz frequency. using this guide:
Quados antenna online calculator - 3G-aerial
http://www.qsl.net/yu1aw/ANT_VHF/quados.pdf
is "quados 8" a good choice?
can i use thicker wire?
why there is no connection to the reflector?
also i don't know where solder the wires exactly!
two sides of the antenna or the two ends of the antenna?
it has a 4:1 balun so 3 center conductors must be soldered to antenna
should i solder two ends of the antenna together? or they must be seperated?
please draw it for me if you can.
thanks a lot
,,,the only method of powering the antenna is the one indicated in the sketch...!!!
