lrg
NITSA-2 / NITSA-2F
The Nitsa-2F universal antenna is designed for use with cellular phones, modems or repeaters of the GSM900/GSM1800/UMTS900/UMTS2100 standards. The antenna type is a two-resonant vibrator with jet loops above the screen. To connect the Nitsa-2F antenna, we recommend using a cable Assembly (75 Ohm)
Operating frequency range, MHz 890-960/1700-2200
Gain, dBi 9 / 9÷11
Bottom width in the H-plane, deg 70/50
Bottom width in the E-plane, deg 70/53
Input resistance, Ohms 50
SWR in the operating frequency range, no more than 1,5
Permissible power, W 20
Polarization vertical
Weight with mounting, g 835
Overall dimensions, m 0,2х0,2х0,045
Connector N-female
The material of the radiator galvanized steel
Protective box material ABS+polycarbonate
Thanks Irg, but I published this antenna before...!!!
This is a feed for an offset dish.
,,, yes, but I think it's one and the same antenna...!!!
,,, I don't know how to do it, I posted something like that before, so there are three -four posts with Antena Nitsa .. !!!
