Nobicom MiMo 21A-200
Antenna 20-Series NOBICOM high – tech product, designed to work in the toughest conditions. The antenna works most effectively in buildings of low and medium density, which reduced the effect of multiple reflections of the signal. In such conditions, the MIMO technology does not give the desired effect, and the cost of the two polar antenna is not justified.
The package includes a fixing rotary device for mounting on bracket or mast.
operating frequency range, MHz - 1900-2700
Gain, dBi 17-20
days Width in H-plane, degrees - 13-15
days Width in E-plane, deg - 13-15
sidelobe not more than-12dB
Isolation between ports, not less than - 35dB
Input impedance, Ohm 50
VSWR in operating frequency range, no more - 1,5
Permissible power W - 50
Polarization vertical/horizontal
Weight, the kg - 3.2
Mount - mast/bracket diameter 20-52mm
dimensions, cm - 45х45х6
Allowable wind speed, km/h - 20
Connectors antenna SMA-female x 2
Connectors adapters (included) - N-male - CRC9 or N-male - TS9
Material protective cover - ABS plastic with UV protection
antenna Material - galvanized steel
fastener Material - steel
screen Material - steel
Protective coating - polymer powder paint
Length of USB cable, m - 10
