Makinarg
Antenna on Dahua Doorbell DB10
Hello Everyone,
I was wondering if you could give me some advice on how to modify the following device. It is a Dahua Doorbell DB10. The range of this doorbell is very limited, which creates a lot of latency problems due to the weak wifi connection.
Perhaps it would have been better to get an antenna extension for the WIFI router, but since I cannot drill the wall to place the antenna facing outside, this was my last option. My idea is to get a cable to solder to the places the antenna was soldered and then connect it to the antenna of a broke router or perhaps build a directional antenna.
If you could be so gentle to inform me, what materials should I use to connect the device with the new antenna:
- Cable RG? LMR? what type?
Any type of information will be much apreciated.
front desoldered.jpgI should weld a piece of the cable from one side to the other, and then from that same side to the antenna, correct?
antenna VLG-2.4G brokewdown.jpgHere i took apart the antenna that was inside the device.
Edited by Makinarg
modify text and arrange images
It's a PIFA antenna (low gain)...Check continuity ...but i think cable (50ohms shorter you can) goes like this
Try with a DIPOLE
Thank you Clanon, I just read in another post that it should be a RG-174 cable.
Now, onto welding the cable, I should weld the copper inner part to the left arrow and the mesh ( that would be ground, correct?) to the place where it is the right arrow. Did I understood it correctly?
Like in this case: 09.jpg
OR LIKE THIS ONE:
right?
Thank you Clanon. I will do this project soon an post about it. Thank you for your help.
GND would have continuity to any of those IC EMI  SHIELDS (aluminum tin  covering circuits) that's COAXIAL SHIELD (MESH) GND...just to be sure...
