acri
antenna freq 5.8 with cdr file
Buddy, I can not open * cdr.file, can you put * dxf.file?
this is the antenna,,,??
I should have some dimensions,,,!!!!
not, different
please help me cek in your swr and simulation
because i dont have tool
1 hour ago, acri said:
open with coreldraw x5 portable
I can"t open with coreldraw x5 portable....!!!!
,,,put another type of file...ex.*dxf.file,,!!!
can you show the difference result?
please check on swr and simulation
Try to remove those extra lines and you will see the result ...!!!~
loco m5?
where is the antenna reflector?
soldering which makes the inner and ground cables
Edited by acri
