bigmdm
Tybrid of two antennas.
I want to create a hybrid of the Turkina antenna and a 3-square antenna. Can you model it?
I want to use two squares as vibrators, but they connect to the cable with a phase of 180 degrees.
Is it possible to calculate the gain and the diagram of this antenna ?
It looks like that this type of antenna does not really work too good...
", with these dimensions ...
An ordinary triple-square antenna gives tremendous results on the wi-fi band. I see about a 80 networks in an apartment building opposite (300m).
Beautiful work, how did you adapt to 50 ohm...??!!!
I connect antenna from 50 ohm cable (10 cm) to a Android tablet. I no adapt this antenna to 50 ohm cable.
This is a experiment. I was build the passive retranslator for smartphone. It is a factory internal tablet wi-fi antenna. Experiment was not effective.
I'll try to do a simulation on 2442MHZ of this ...
...these calculations do not correspond to reality....!!!!
  On 12/6/2017 at 11:31 AM, bigmdm said:
Ok. Please cutting the balancing loop and calculating again.
okay,but this is reality....
When I assembled this antenna the first time, I did not do the balancing loop. Those who collect this antenna for 3G band also do not recommend place the balancing loop.
