pragata.my.id
Scheme, Sectoral MIMO Circular
is there anybody want to help me make a CST simulation for this antenna scheme that i made this.
sorry, for the distribution link i have not counted it .. i just want to know how big the signal streng and radiation by this antenna scheme.
Thank you, but tell me what it"s the distance between the patches...??!!!
,,,and the length of the impedance adjustment lines?
I mean spacer = the distance between the patches.
the length of the impedance 50ohm, i hope to focus on frequency 2.422 Mhz.
When the distance between the patches is far away, the dimensions will be smaller, this is usually used for close proximity to wider radiation.
can you make the right size so that the gain is large, the point is I want to layout antenna like this, shaped length and width about 100mm, so I can put in pvc pipe.
my low-powered laptop can not install antenna modeling software like CST, magus ,.
Yes, it looks like this antenna is good ... !!!
MiMo Circular Polarization
No, it's still working on the impedance.
Your drawing on CAD is on PCB...??
I took the imagination from the brain to corel draw. still do not understand about the good impedance that how.
