3G/LTE ANTENNA " BAS-2303 ULTRA 3G/4G»
The bas-2303 Ultra 3G/4G antenna is designed to work with any 3G and 4G modems equipped with a CRC9 antenna connector. Operation of the bas-2303 Ultra 3G/4G antenna allows you to increase the range improve the performance of wireless devices in 3G/4G/Wi-Fi networks, improve the stability of the connection in adverse weather conditions and increase the data transfer speed. For ease of use, the main cable has an FME-female connector, and the FME - CRC9 adapter is included in the delivery package.
SPECIFICATIONS
The location of the antenna:Outer
Supported communication standards:GSM1800 (2G), LTE1800 (4G), WCDMA2100 (3G), IEEE802.11b/g/n (WiFi), LTE2600 (4G)
Operating frequencies, MHz:1800-2700
Gain factor, max., dBi:12-18
The standing wave ratio on voltage not more than:1.5
Wave resistance, Ohms:50
Cable length, m:5
Connector type:FME/CRC9
Overall dimensions (without mounting unit), mm:1010x110x70
Weight, not more than, kg:0.89
Dimensions in the package, mm:290x170x80
Package weight, kg:1
