Hamza
HELP
is it possible to make  cantenna for 1800 LTE  and whats the central frequency and the optimal  diameter of can ? thanks  by advance
19 minutes ago, Admin said:
,,, install this program and you can configure any Cantenna ...
Cantennator_Setup.exe
https://www.changpuak.ch/electronics/cantenna.php
why i GOT  big differentS resultS  of 2 calculaters (  fr 1795 ,DIAMETER 110 MM)
CHANGPUAK  L = 0.75*LG = 122.16    / cantennator = 274.4 ( so long).
CHANGPUAK  LG/4 = 40.72 mm /  cantennator = 91.5 mm ( distance bottom to probe)!
any way  for DIYER  changpuak calculater is suitable  becuz  cantennator needs very long can (274 mm)   but  wich programm is right ???
Length is any size ...more than 3/4 lambda...(more directivity more lenght)
i agree CLANON  But the 1/4 lambda guide   is  so different ,   WICH PROGRAM IS  CORRECT
Hamza, see this too and turn it into a frequency of 1800 MHz LTE Cantenna...
k=2,66/1,8=1,477  ( multiplication factor)
Thx jomy I ll try it
