jnkwqlqn
698-3800 Mhz Yagi
53 posts in this topic
On 1/18/2021 at 4:11 AM, clanon said:
i build a model...check it ou...(didn't like the resonances...small S11)
yagi.cst
Hi Clanon, the cst file had some problem. Anyone can provide me the cast file?
9 hours ago, clanon said:
you're RIGHT ...i was tweaking and fiddling with it...trying to get the  S11 right....(closer to the measurements...)
i think that the cylinder thing helps widen the band...and NOT sure about the port distance (dipole gap)
dont forget the IMPEDANCE MATCH with 125ohms quarter wave...
I think the impedance match cable are half-wave length without shielding (not sure how many ohm, but I suppose is 125 ohm)
5 hours ago, clanon said:
i think i'm close...2.3ghz is not showing REMEMBER to use a 300 ohms port
yagi.cst
Why 300 ohm is used? the cable is 50 ohm, and I am using 50ohm tested it out
50 ohms to 300 ohms (ALLFOLDED DIPOLES)
quarter wave transformer 123 ohms (125)
is a 2020 file you can't open it with an older version
I see, but the 125ohm cable is half-wave length. May be you can simulate the result in 125 ohm?
Any ways to open 2020 file in 2017 version?
i could save on the other formats  drawing only...
TRY to IMPORT from 3d
Yagi 3 formats.rar
dont't forget if you don't adapt to 50  ohms USE 300 Ohms port... (or build the adaptor of 125 ohms) not easy...
Clanon, your antenna is not positioned at the zero point of origin...!!!!
...SO....? you can make ANY point your point of origin ...translating the WCS...
CHOOSE any point and make it! Point zero
9 hours ago, Admin said:
,,,such a thing is not common in design...!!!
Where is the ZERO point in SPACE (REAL AIR or Vacuum)...?
So did you simulate it in CST yet? Thanks.
Edited by jbckdsav
the right name for "698-3800 Mhz Yagi" is "Log-periodic antenna"  =)
HERE IS ONLY YAGI, NOT LOG-PER...!!!
New test with short cable. Seems less than 2.5 VWSR.
This results from seller right? Don't misleads by the seller.
On 1/19/2021 at 7:25 PM, clanon said:
Thats what they gave me.
Edited by jbckdsav
The results they shown are also bad. Swr 2.1 at 1.7Ghz...
Please take your time to read my previous results and clanon simulation results...
Product Description
Frequency Range:690-960/1710-3800 MHz
V.S.W.R:≦1.5
Gain:12/16 dBi
Cable Length:1,2,3Meter etc.
Polarization:Vertical
Cable Type:RG174 or others
7 hours ago, jbckdsav said:
So how wideband is this antenna?
It's wideband by several PEAKS of resonance...if your frecuency of interest doesn't FALL inside one of those you're  out of luck...
So it's NOT continuos WIDEBAND like other designs...
3 minutes ago, jbckdsav said:
No, 2 is 2.5 i think.
my bad! it cant never be under 1:1
