AX-1700 OFFSET BOX
Offset irradiator in the range of 1670-1720 MHz. Ra=50 Ohms. GAIN=10 dBi. It is intended for use as part of equipment (mirror antennas) for receiving L-band RCPH signals from geostationary satellites.
Electrical characteristics
Operating frequency range, MHz 1670 - 1720
Native gain, dBi 10
The resulting CU and radiation pattern width in terms of level is 3 dB for different diameters of an offset parabolic antenna (at a frequency of 1695 MHz) with an F/D ratio of 0.5
0.55 m 17,5dBi 21 gr.
0,6 m 18,6dBi 19,5 gr.
0.9 m 21,7dBi 14 gr.
1.3 m 25dBi 9 gr.
1.5 m 26,4dBi 8 gr.
Width of the bottom of the irradiator in the H-plane by level-10dB, deg 100÷115
Width of the bottom of the irradiator in the E-plane by level-10dB, deg 100÷115
Input impedance, Ohms 50
SWR in the operating frequency range, max. 1,3
Permissible power, W 10
Polarization of the irradiator\offset mirror antenna left\right circular map
Weight, g 300
Overall dimensions, m 0, 145x0,145x0, 154
Connector SMA-male on flexible cable
Irradiator material galvanized steel
Protective coating powdered polymer paint
Material of the protective box ABS+Polycarbonate
