АНТЕННА 3G/4G "BAS-2344-SMA FLAT MULTIBAND MIMO COMBI"
DESCRIPTION
Panel antenna for outdoor placement. It is used with USB modems that support MiMo technology, which can provide faster connection speeds.
The main feature of the antenna is a wide band of operating frequencies, in other words, the antenna works on all bands of mobile operators.
The antenna is directional and equipped with a 50 Ohm cable and a standard SMA-male connector. To protect against static electricity, the antenna has a DC circuit closure. The antenna structure is covered with a radio-transparent plastic housing that protects against UV radiation and most adverse weather conditions, increasing the product's service life. It is installed on a mast or bracket with a diameter of up to 50 mm, allowing for more precise adjustment to the mobile base station.
SPECIFICATIONS
The location of the antenna:External
Operating frequencies, MHz:790-860, 1700-2700
Coefficient of strengthening, max., dBi:9 / 13
Standing wave voltage coefficient, max:1.4
Wave resistance, Ohms:50
Maximum input power, W:40
Cable length, m:5
Connector type:SMA
Built-in Wi-Fi adapter :no
Assembled dimensions (without mounting unit), mm:275x245x87
Weight, not more than, kg:0.8
Package dimensions, mm:290x250x120
