Broadband MIMO irradiator KIP9-1700/2700 DP for satellite dish
The feed offset parabolic antenna KIP9-1700/2700DP MIMO 2x2 is designed for use with 3G/4G/WiFi modems and routers. The radiator supports standards LTE1800, UMTS2100, LTE2600 and WiFi(2.4 GHz) 802.11 b/g/PS 2x2 MIMO in the frequency range of 1700-2700 MHz. If you have a 4G modem, and Internet speed and signal strength are not satisfied, then the use of bundles 4G irradiator plate surely will boost the signal. Because of MIMO standard doubles the bandwidth of the channel.
Amplification up to 35 dB.
Antennas-characteristics :
Operating frequency range, MHz 1700-2700
Antenna gain, dB 8-9
SWR in the operating frequency range, max. 1.5
Polarisation Linear
Input impedance, Ohms 50
Maximum input power, W 10
Connector F- female N- female
Permissible wind load, m / s 30
Operating temperature range, oC -40 … +50
Maximum permissible air humidity, % 100
Crosspolarization decoupling not less than, dB 30
Communication Standard
WiFi 2400
LTE 2600
UMTS 2100
LTE 1800
Multi-band
Mounting type on the pipe
Execution type irradiator MIMO
and inside...
,,, some dimensions ...
Kroks Rt-Pot sHw DS modem Huawei E3372, built-in antenna
 For installation in offset dish on a mast on the wall or on the window sill. Built-in WiFi antenna 2.4 GHz. 4G speed up to 70 Mbps, 3G up to 35 Mbit/s Power DC 24V twisted-pair.
Kroks Rt-Pot sHw DS is a router with 4G the modem and the illuminator built into one housing. The router has several types of mounts included in the package. Private gain of the radiator is 8-9 dB. The operating frequency is in the range of 1700-2700 MHz. MIMO technology supported by the irradiator in the entire frequency range, dual channel bandwidth. The device is running OpenWRT operating system that provides bandwidth allocation (QoS), firewall, user access control and many other features.
mPCI modem allows you to get the maximum possible speed 4G Internet that may not always provide a USB modem.
Built-in WiFi antenna, support 2.4 GHz standards 802.11 b/g/n and provide communications range up to 50 meters in open range.
I finally managed to do a simulation with this antenna....
1 hour ago, prda said:
Can I get the dimensions of this antenna and what material it is.
,,,dimensions are shown in the images above...!!!
