Mimo delta 20lte antenna
Manufacturer: Delta Satellite
Model: Delta MIMO 20 LTE
Band, MHz: 2500-2700
Gain factor, dB 2*20
Vertical / Horizontal polarization
VSWR less than 1.5
Connector 2 n connectors (Female)
Operating conditions -40 +80
protection against moisture and dust IP 54
Overall dimensions 370*370*25
Weight, kg 2.0
Additional information:
Delta 4G-20 (MIMO LTE) antenna)
Powerful 2x20 dB, two-polarization MIMO (vertical and horizontal polarization), directed 20°X20°, all-weather IP54 antenna on the range of 2.5-2.7 GHz 2600 LTE (Band 7, FDD 2600) is designed to work as part of modems, routers, routers, LTE-4G access points.
Provides maximum connection speed and stable operation in 4G networks for Yota, MegaFon, MTS, Beeline, Tele2 operators in conditions of uncertain signal reception.
The 4G MIMO antenna is connected to a modem or router via cable assemblies and allows the antenna to operate on a 4G LTE network.
