PETRA-12 MIMO USB BOX Antenna for 3G/4G
Sealed box for 3G / 4G modem with built-in wide-band MIMO antenna and integrated 10-meter USB cable. The device is completely ready for self-installation: inside the case you will find two CRC9 pigtails for connecting the antenna part to the modem, and the complete mount will allow you to easily install the PETRA-12 MIMO 2x2 BOX on a facade bracket, pole or remote mast. Nothing prevents the device from being used indoors as well!
Communication standardsGSM-1800, UMTS-2100, LTE1800, LTE2600
Frequency range 1700-2700 MHz
Gain factor 10-13 dBi
Bottom width in the H-plane 30–48°
Bottom width in the E-plane 46–63°
Input impedance 50 ohms
SWR in the operating frequency range≤ 1,6
Polarisation vertical + horizontal
Permissible power 10 W
Forward / backward ratio 14-15 dB
Side lobe level≤ -10 dB
Decoupling between ports in the operating range≥ 32 d
RF connectors 2 x CRC9
USB Cable Length 10 m
Antenna Material FR-4, galvanized steel
Material of the protective box polycarbonate+ABS
Mounting material galvanized steel
Shell Protection IP54
Permissible wind speed 25 m / sec
Operating temperature range-40°C to +80°C
Size 260 x 135 x 90 mm
Weight 1 kg
Equipment PETRA-12 MIMO BOX antenna with CRC9 connectors, 10 m USB extension cable, pipe or mast mounting kit, user manual
,,,Petra 12 antenna simulation...
,,,with Guanella Adaptation...
A new attempt at impedance equalization,with a single port...
,,,and some other dimensions...
,,,a MiMo construction variant with rectangular patches...
