AX-2515P UniBox MIMO 2x2 Antenna
Electrical characteristics
       AX-2515P MIMO 2x2 UniBox
       Operating frequency range,   2500-2690 MHz
       Gain,  14÷15 x 2 dBi
       The width of the days in a horizontal / vertical plane,  30÷36 degrees
       Onoshenie forward/backward >20 dB
       The sidelobe level is not more -14 dB
       Isolation between ports, not less 28 dB
       Input impedance,  50 Ohm
       SWR in the frequency range, not more 1,5
       Permissible power  50 watts
       Polarization Dual slant (X-Pol)
       Weight with mount,  1900 gr
       Mount for mast diameter 20-52mm
       Range of working temperatures, -60....+80 C. Celsius
       Overall dimensions without mounting,  0,24х0,24х0,1m
       Allowable wind speed,  25 m/sec
       Antenna connectors 2хЅМА-male
       The material of the protective casing Polycarbonate+ABS
       Antenna material galvanized steel
       Fastener material steel
       Protective coating powder polymeric paint
