PETRA-9 MIMO 4x4 Unibox-2
Petra-9 MIMO 4x4 Unibox-2 is a 3G/4G antenna combined with a spacious sealed box (Unibox-2/Unibox-2L) in which you can place an LTE modem with support for MIMO 4x4 technology or two modems with support for MIMO 2x2 technology. The antenna is equipped with reliable connectors-SMA-male (50 ohms). Antenna adapters for connecting LTE modems are not included. The modem communicates with an indoor PC or router via a USB extension cable (USB 2.0).
If the router is installed inside the box, the antenna can be equipped with a sealed PG-7 or RJ-45 pin (instead of a USB extension cable)
Electrical characteristics of the PETRA-9 MIMO 4x4 UniBox-2 antenna
Operating frequency range, MHz 1700÷2700
Gain factor, dBi 8,5÷10
Bottom width in the H-plane, deg 59÷82
Bottom width in the E-plane, deg 35÷57
Side lobe level, max -7 dB
Decoupling between ports in the operating range, not less than 25 dB
Input impedance, Ohms 50
SWR in the operating frequency range at the inputs, max. 1,5
Permissible power, W 10
Slope of polarization of received / emitted waves -45°/+45°(X-pol)
Weight of antenna, mount, box, extension cable g 1900
Bracing mast diameter 20-52 mm
Operating temperature range -60°C to +80°C
Overall dimensions without mounting, m 0, 24x0, 24x0, 1
Permissible wind speed, m / sec 25
Connectors 4 x SMA-male
Material of the protective cover -Polycarbonate+ABS
Antenna Material -Galvanized steel, brass
Mounting material steel / Polycarbonate+ABS
28 minutes ago, Antenna gun said:
please show me how to make them
,,, okay, I will try to do a simulation with this antenna...!!!
An approximate model of one element without exact dimensions and optimization.
Only the principle of construction.
,,, and from the front ... ??? ,,, this is Bester antenna ... ??
,,, what does it look like from the front .... !!!
Bester...
,,, well then, if you have a sample why not do a simulation with it ... ??? !!
I don't have this antenna. I can only roughly predict the dimensions. Above, I laid out the estimated modeling, but it seemed to you not interesting. I adjusted the dimensions to good results at 75 ohms.
I drew a 50 Ohm model in the original design. And played around with the size a bit. There is a reserve for tuning. I think I can get results like the 75 ohm option or better.
Petra 9-simulation and dimensions...
