Reply to PETRA-9 MIMO 4x4 Unibox-2
Harry36
By Harry36,
I don't have this antenna. I can only roughly predict the dimensions. Above, I laid out the estimated modeling, but it seemed to you not interesting. I adjusted the dimensions to good results at 75 ohms.   I drew a 50 Ohm model in the original design. And played around with the size a bit. There is a reserve for tuning. I think I can get results like the 75 ohm option or better.
