ZETA F MIMO-4G/3G/2G
Powerful budget broadband panel antenna 2G / 3G/4G / WIFI. Gain 17.5-20.0 dBi. Ra=75 ohms, MIMO.
General information:
The ZETA F MIMO panel antenna is designed for use in a set of equipment for wireless data transmission systems.:
cellular communication (GSM1800) 2G (EDGE) 3G (UMTS 2100) 4G (WIMAX,LTE) WI-FI (IEEE 802.11b, g) and in other systems in the 1700-2700 MHz band.
Electrical characteristics
Operating frequency range, MHz 1700-2700
Gain in the GSM1800 range, dBi 17,5-18
3G gain (1.9-2.2 GHz), dBi18-19
WIFI gain (2.4 GHz), dBi19,5
4G (LTE) gain, dBi 19,5-20,0
Bottom width in the H-plane, deg 15-26
Bottom width in the E-plane, deg 15-26
Side lobe level, max -12 dB
Cross polarization level, max -25 dB
Input impedance, Ohms 75
SWR , max 1.6
Permissible power,10 W
Polarisation vertical+ horizontal/ X-pol
Weight with mounting, g 2705
Bracing mast diameter 20-52 mm
Overall dimensions without mounting, m 0,4 x 0,4 x 0,035
Connector 2 x F-female
Material of the protective box Polycarbonate+ABS
Antenna Material galvanized steel
Mounting material steel
Protective coating powdered polymer paint
