AX-2000 OFFSET 75
The ANTEX AX-2000 OFFSET 75 irradiator complete with an offset mirror antenna (not included) is designed to increase the range of 3G modems in the 1705-2175 MHz range . A mirror antenna with an irradiator significantly improves the quality of communication at the borders of 3G service areas. The active vibrator of the irradiator is securely hidden from precipitation and aggressive influences in a plastic case.
Overall dimensions, 120x120x60mm
To choose the right diameter of the "plate", refer to the following table:
Antenna diameter-Resulting gain factor
0.55 m-19 dBi
0,6 m-20 dBi
0.9 m-23 dBi
1.2 m-26,5 dBi
1.5 m-28 dBi
Thus, the larger the antenna diameter, the greater the gain.
We recommend: use antennas of 0.55-0.9 meters, because they have a relatively small windage, use" plates " of domestic production. But you can also use any other offset antenna.
The antenna has an impedance of 75 ohms, in the model the port is -50 ohms. Is the design not original? In the original, the antenna is offset from the center of the reflector. The radiation pattern deviates from the normal ~ 5 degrees.
I do not have the dimensions of the original antenna and the impedance can adapt to 75 Ohm.
parallel stripes (transmission line )  width...separation ?
distance to reflector...?
,,,see the cst*file(T-Antenna) above...!!!
i didn't see it...GREAT!
i'll check it now
CAN 't OPEN it is newer version...Cst2020 mine :/
,,,try with cst2021...!!!
,,,or maybe I'd better give you the drawing ...!!!
