Guest
Mysterious s21 coplanar waguide
28 posts in this topic
,,, in the gap put a circular metal addition of 0.1mm...!!
ok, i can try this but when the board will the sma will be mounted in the board
How can we precess to remove the gap without a short circuit?
If your goal is to get to 15GHz and more you are using the wrong connector.
You need an SMT edge connector (I would prefer a 2.92mm connector), lowers the problem with ground
Why did you cut open all metal layers? There is no need for that it only introduces unwanted effects.
