rob
yagi 2.4Ghz yagi
245 posts in this topic
i've been using a non-isolated yagi antenna.. so far no problem..
,,,, the thickness of 5mm aluminum seems a bit big to me .. !!!
,,,post a picture with this antenna, if you can ... !!!
15 hours ago, Ivan_it said:
where to find the latest and working version of the antenna
i think  none speaks about the  thickness of  feed  ??  its  so important for the impedance ?!!!!    any idea ?
20201208_162507.jpgthis is the antenna i made for 2.4ghz (wifi antenna )
Edited by Vasuki
Vasuki,I gave you a solution above, if you want to consider it, well, if not, I think it is unuseless to continue the discussion...!!!
Okk i will try that one thank you.
Yagi patch 2,4 GHz   14-15  DBi  inspired by Jomy
,,,congratulations...!!!
,,, and how does it work .. ???
7 minutes ago, Admin said:
Unexpectedly  high performance with just 6 elements and shorter boom it's performs  like BDM 22 elements . Thank you jomy ..
1 hour ago, Hamza said:
REFLECTOR area ...must be IMPORTANT
I think  adding bucket   it gives more directivity and more gain    I appreciate it. It's  just 20 cm  , just 6 elements and light weight  I ll write by the dramel JOMY ANT. on the reflector. You are really genius ☺️
,,,,,Here you have said " with the correct connector " will connector matter the quality of signal ?? !!!!!
If so which connector and wire should i use for 2.3ghz antenna ?!!!!!
You can use something like this from old wall clock if you don't like soldering
50 minutes ago, Admin said:
,,, for you simpler ...
Thank you so much
Thank you so much
3 minutes ago, Vasuki said:
Thank you so much
The second conductor should also be in contact with the modem ??
Edited by Vasuki
1 minute ago, Hamza said:
Or like this
What is this connector called ?
