rob
yagi 2.4Ghz yagi
245 posts in this topic
0.25 is disc thickness, 10 is SMA connector's distance from the radiator's edge, both in millimeters.
The diameters of the reflector, radiator and first director are 90, 68 and 54 mm, respectively, with 5.75mm and 9mm gaps in between.
,,, a simpler and improved version...
,,,notched vibrator and supplied directly with coaxial cable...!!!
Thank you sir for prompt reply.
MiMo Bester after optimization....
,,, constructive details ...
Can you please guide for rod base yagi for 2.4 g?
I have 3 mm long aluminum wire and 10mm thick wooden strip. Want to make yagi for it.
Edited by Guyton
,,, here you can find what interests you ... !!!
Could you guys tell me if you think this design could work? I am building a 2.4ghz yagi disk cantenna, but I am unsure of the separation distances and copper circles.
Edited by Fir3shoxk
,,, it's stupid ... !!!
,,,, and mcneil's antenna is a fake...!!!!
Oh my thank you so much! What would you recommend then if I were to build a cantenna yagi disk?
On 3/6/2020 at 10:46 AM, Admin said:
,,, this is a simulation with 8mm rod....
The constructive dimensions...
Does this design still work or is it flawed?
Am I correctly connecting the SMA to the antenna? For some reason it isn’t performing as good as I wanted it to.
,,, not good, very rudimentary, still studying ,, !!!
try using the SMA connector.
,, or do it yourself...
I finished making my antenna guys and it's working .
is there any thing i can improves it with like adding something Pringles can maybe ??
,, the connection between radiator and vibrator is not visible...show it...!!!!
that black thing is just glue to make it more stable
,,, such a thing cannot be done..!!!!
,,look better on this forum...!!
,,,other dimensions, another wifi-shotgun antenna...
In it something is. Thanks for the help in this question, can I too I can to you than that to help?
sassa
feedpoint (SMA) to the center c=20. is there any standard method on the calculation? most of the time it is about 1/3 to 1/4 from the R=90 in this case
,,,the  feedpoint is chosen relative to the vibrator and not to the reflector...!!!
,,,as you can see, this is chosen to ensure a wide frequency band...!!!
oh ok, so the feedpoint location is it safe to say around ~ 1/3 length location from the center of the V? I still cannot find the correct formula for this. or is it  to be autocalculated in the CST software?
