Directional panel 4G MIMO antenna KAA20-2600
 KROKS KAA20-2600
Dimensions (length , width , height ), mm 445  x   445  x   80
Antenna characteristics:
Operating frequency range, MHz 2400-2700
Antenna gain, dB 20
VSWR in the operating frequency range, not more than 1.7
Polarization Линейная
Input impedance, Ohm 50
Maximum input power, W 10
Connector N- female F- female
Permissible wind load, m/s 30
Operating temperature range, °C -40 … +50
Maximum permissible humidity, % 100
Port isolation, not less, dB 30
Communication standard WiFi 2400 LTE 2600
Type of mounting на трубу
Execution type Панельная
