Cross Antenna
The cross antenna is a medium gain and circular polarization structure made of a conductor or a strip line over the ground plane following a cross contour of four or more branches.The construction repeatability is verry easy as well the facility to obtain 14dBi gain in a small antenna.
Can we use this shape for 2.4ghz?
I first time see such a design !!!
with what dimensions?
Yes, it can ... but I can not find the file at this time...!!!
,,,like the 2.4GHz cross-antenna, with a reflector diameter of 240mm...
In general ...can we use this dimensions (from colinear antenna) to build this one?
27mm, 6mm, 27mm,
like is on picture?
,,, not, under any circumstances ....!!!
Very interesting model! Any generic rule for the design? thanks. I mean explanations.
Edited by tomasbj
Could you please explain how the wire ends in this design?
Apart, I understand the wire lenght should be lambda/2. Am I right?
Do you have a .cst file to check the design?
Thanks in advance for your help.
