BESTER BDM-2 3G ANTENNA, 15dBi
37 posts in this topic
,,,thanks buddy....!!!
,,,,, yes I think this it"s ... !!!
or like this...
,,,,,You're right.
or like this...
>>>>>You're wrong.
!!!!!...They are very similar. You only need to increase the pin...!!!!!
I use F connector with my new patch-yagi or wifi gun antenna and work ,also i use kO-Ka 3000 75 ohm coax
 Who has the correct drawing with dimensions for bdm 2100 mimo and 75 ohm cable?
On 09.12.2019 at 19:17, Admin said:
Но почему бы вам не попробовать...???
suitable for 75 ohm cable ?
,,,not!
but why do you want to use 75 Ohm coax cable... SOMETHING LIKE THIS IS NOT USED...!!!???
3 hours ago, Admin said:
,,,нет!
но почему вы хотите использовать коаксиальный кабель 75 Ом... ЧТО-ТО ТАКОЕ НЕ ИСПОЛЬЗУЕТСЯ...!!!???
no other cable.
there is another drawing under 75 ohm
Hello. Who has the correct drawing with dimensions for bdm 2100 mimo and 75 ohm cable?
75 Ohm with this type of connector....!!!
Hcc3eb6f6e47e45ab90cc25b3db7c40ddP.jpg.532df404b5a8e66d407a421543cc6a54.thumb.jpg.e6e3eaa5fd08af209379e2f1ef87bfb9.jpg
,,, that's how it's mounted...
Quote
Are these dimensions correct for a 75 ohm cable?
I have such an antenna did not work.
