calipso99
In need of a 3G 900mhz Dish Feed antenna
Hi. I'm here once again in need of your help. Need a small and simple 900mhz (890-960mhz) 3G Dish feed to test signal from the last Mobile broadband provider in My área. @Admin if You see this post i'm the guy You designed that 1900mhz Feed for. It worked great (managed to get -47dbm from -75dbm) but the internet connection at the cell tower seems to not be the Best so i need to try with the last provider in My área and see if it Suits My needs. Again thanks for the help.
,,,for which the antenna is in three variants ... ???
,,,first variant...
900 MHz.cst
,,, it is still possible ... !!!!
  On 1/24/2022 at 7:04 AM, Admin said:
,,,для чего антенна в трех вариантах...???
,,,первый вариант...
900 МГц.cst
Does this antenna work with a 75 ohm cable?
Hello!
I'm sorry, and the size of this antenna can I know?
I don't have this file anymore...I have to restart the simulation from the beginning...!!!
,,, this would be the simulation and dimensions...
  On 7/17/2023 at 6:21 PM, Admin said:
,,, это была бы симуляция и размеры...
good morning! which dimensions should i change to connect 75 om cable?
you are faster than me))
to connect 75omh cable feed gap must be wider!
also change some dimensions))
and gain!
Edited by Pupe
change label
,,,but for you, the resonance frequency is 625 MHz and the impedance is crazy...!!!!
I think it can be recalculated for 900MHz. Then also the size will be a little smaller.
