1 pc ADS-B active receiving antenna 1090 MHz
1) Operating frequency: 1090 ± 15MHz
2) Passive gain: 2dBi (dipole antenna)
3) Antenna polarization: Omni-directional vertical linear polarization
4) Active gain: 20dB
5) deviation from the external range: >30 dB
6) Working voltage: 2.5-5.5 V (negative core only)
7) Working current: 80mA
8) System resistance: 50 ohms
9) Antenna weight: 15g
10) Dimensions: 20 × 170 mm
11) Connector shape: SMA standard female head (outer inner screw hole)
