Antenna LTE H4G DESPITE 2x15 dBi of 1.8-2.1 GHz SMA 2x5m
H4G antenna, antenna gain 15dBi. This is an external antenna, highly directional, designed for mobile communication systems LTE, UMTS, HSPA+, operating in the range of 1.8-2.2 GHz. Perfectly resolves issue where the signal 4G/3G is too weak for proper operation of the modem or repeater. Just attach the antenna to the modem to improve signal strength and surf the Internet.
Feature of antenna: circular polarized antenna H4G does not require attention to correct installation polarity antenna as in dipole antennas of the type Yagi-UDA, or panel.
This simplifies installation of the antenna, even people who do not know technical problems.
Other features:
Modern compact design, helicalna construction, gives a high gain in a wide band
frequency is moved.
Hermetic and durable casing to withstand extreme weather conditions, which guarantees
a long and reliable performance.
Mounting bracket allows wide range of diameters of used masts.
The mounting bracket allows the tilt of the antenna 50 degrees in the vertical plane, a parameter important
in mountainous terrain.
Uses high-quality materials - copper, aluminum, galvanized steel, plastics
change.
Name    H4G
Cable 2x    5 m
Connector 2x    SMA
Profit energy max[dBi]    15
Range [MHz]    1800-2200
Polarization circular    circular
The standing wave ratio    <1,4
The angle of half-power radiation [str]    30
Suppression rear view P/T [dB]    23
Resistance [Ω]    50
Dimensions length x width [cm]    45x12
Weight of antenna with 5m cable [kg]    0,7
Support plate diameter [mm]    43
